Viewing received DMX
Command |
Path |
DMX Viewer |
DMX |
When a lighting console is connected, you can view the DMX information sent from the console.
The DMX Viewer does not work with MA-Net3.
To view the DMX information:
Select the command.
The DMX Provider dialog box opens.
Specify the protocol to connect to the lighting console, and click OK.
The DMX Viewer opens. This is a separate dialog box that opens along with Vision, and it can remain open while Vision is running.
For each selected Universe, the current DMX information sent from the console displays. The Display Type can be toggled between Decimal and Percentage.
Click X to close the DMX Viewer.
